Burning oil
Old Dec 21, 2013 | 02:48 PM
  #21
Reesey's Avatar
Reesey
<p>Even better. Easy job for the gasket. What could cause the hot and lean running? By the time i get done this will be a brand new truck in an old body.
Old Dec 21, 2013 | 03:06 PM
  #22
92DakotaClub's Avatar
92DakotaClub
o2 sensors... they are new arent they? they need to learn.. ALSO when u did change them did you disconnect battery to clear computer so it could relearn properly..
i wouldnt worry to much tho .... if they were black or saturated with oil i would worry , or if they were SOLID white i would worry
if you want to double check a quick check on plenum... take breather top off open throttle full and flash a light down there if you see oil pooling .. problems arising ..
Old Dec 21, 2013 | 04:36 PM
  #23
Reesey's Avatar
Reesey
Double post
Old Dec 21, 2013 | 04:37 PM
  #24
Reesey's Avatar
Reesey
Did disconnect to reset the computer, yes. I will check the throttle for oil pooling, and replace the cover gaskets. I also have no idea how long those plugs have been in, but its definitely the next item on the to-do list since I will be replacing the cover gaskets. Just starting to get time to do all of this. Took a 100 mile trip right after I replaced all the things above I am getting a definite change(for the better) in how my truck is running. Cant wait until it is all done, if ever.
Pic of my old red:
