front end problems
Old Dec 28, 2013 | 12:15 PM
jbrown13's Avatar
jbrown13
Default front end problems
I have a 95 Dakota and the other day I hit a fence post on the front right side. no body damage so I think hit the tire. now my steering wheel is turned toward the left going straight down the road and the truck is pulling horrible toward the right can barley keep it in the road. does this sound like a bent tie road or something worse.
Old Dec 28, 2013 | 01:36 PM
Tom A's Avatar
Tom A
Section Moderator
It definitely sounds like a bent something. You shouldn't drive it until the problem is fixed. Jack it up and inspect everything, including the control arms. Compare the two sides and make sure the right looks like the left.
If you have any doubts about your abilities, get it looked at by a pro. Steering isn't something you want to mess with if you don't know what you're doing.
Old Dec 28, 2013 | 06:58 PM
92DakotaClub's Avatar
92DakotaClub
well if its 4x4 it might have bent the centerlink/drag link , idler arm, pitman arm...
cant remember if the 2wd had a rack in 95 but if so more then likely inner tierod if so ..
when my passenger front tire caught the front clip of a car trying to switch lanes...... I bent my idler arm and centerlink on my 92 4x4 .... bastard was lucky my tire caught front of his car , not my bumper... but I still wrote his car off....
Old Dec 28, 2013 | 10:39 PM
shadowthedakota's Avatar
shadowthedakota
2wd had the rack. in 97 is when the 4x4s started using the rack also
Old Jan 7, 2014 | 10:29 AM
jbrown13's Avatar
jbrown13
UPDATE... put new upper and lower ball joints on the right side. carried it to have front end aligned and was told I needed ball joints on left side. on right side I needed a inner tie rod and wheel baron before he can align it and he found while up on rack that the right motor mount was busted. that fence post is going to end up costing me a lot of money.
Old Jan 7, 2014 | 12:33 PM
92DakotaClub
inner tie rod? so its 2wd then ... some of the damage could have just been normal wear and tear aswell but a motor mount? jeeze what u hit? a concrete pillar?
Old Jan 7, 2014 | 07:38 PM
jbrown13's Avatar
jbrown13
close to it. this was concreted in the ground
Old Jan 13, 2014 | 02:20 PM
jbrown13's Avatar
jbrown13
got all my parts on and carried it to get aligned and they got it very close the tech said its a little off he couldn't line it up perfect because the right spindle is bent but it drives a whole a lot better. now another part to change mo money mo money lol.
