Blown Radiator, now check engine.
Old Feb 4, 2014 | 02:59 PM
marcar1993's Avatar
marcar1993
Default Blown Radiator, now check engine.
My radiator blew on my truck yesterday (93 3.9l 5 speed 4wd). I replaced it, the water pump and the thermostat too for good measure. When I fired it up it was surging and threw codes 22 and 62. I disconnected the battery to clear the codes and restarted it. It was still surging at idle and throwing code 22 (Coolant temp sensor output invalid?)
Thoughts on what it could be? What should my output voltage/resistance be on the temp sensor if I were to test it? It's the one wire connector on the front pass of the intake right?
Old Feb 5, 2014 | 12:14 AM
master tech's Avatar
master tech
Site Moderator & Tech
Code 62.
PERFORM THE SRI DISPLAY "WRITE POWERTRAIN CONTROL
MEMORY TEST. FAILURE"? MODULE.*
NO
WITH THE DRB,
NO DOES THE DRB YES PERFORM THE SRI
DISPLAY "WRITE MEMORY TEST A
REFUSED"? SECOND TIME.
DOES THE DRB YES REPLACE THE
REFUSED" AGAIN? MODULE.*
NO
DOES THE DRB YES UPDATE THE MILEAGE
DISPLAY "SRI AND RETEST THE SRI
MILEAGE INVALID"? MEMORY.*
NO
COMPARE SRI
MILEAGE STORED IS THE MILEAGE YES RETEST THE SRI
VALUE TO THE WITHIN THE DRB MEMORY.*
INSTRUMENT PANEL SPECIFED RANGE?
ODOMETER MILEAGE.
NO
UPDATE THE MILEAGE
AND RETEST THE SRI
MEMORY.*
Code 22 is either ETC sensor volts too high or too low. I do have PDF files for these codes. If you need then, send me a pm with you email.
Old Feb 6, 2014 | 11:18 AM
shadowthedakota's Avatar
shadowthedakota
i had the same thing happen when the rad blew in my old 93(minus the codes). i replaced both ects and the problem went away.
the ect sensor for the pcm probably went bad(since you have code 22) and that would cause the truck to go into limp mode which would explain the surging(which i found out when i installed a new engine wiring harness).
Old Feb 6, 2014 | 08:38 PM
marcar1993's Avatar
marcar1993
Ok, I bought the sensor, now I just can't see it! I know about the one wire sensor for the gauge, but where is the 2 wire sensor for the computer mounted? Under the a/c compressor? Does it and/or the bracket need to be removed?
Old Feb 7, 2014 | 12:27 AM
shadowthedakota
It's behind the ac and more than likely. I don't remember how I did it but I believe I removed the bar and did it without removing the compressor. While you are changing it check the connector for corrosion.
Old Feb 8, 2014 | 09:11 AM
marcar1993's Avatar
marcar1993
Thanks, I pulled the compressor. It was easy to get to then. I realized two things though, one the store gave me the wrong part and two the connector unplugged itself. I suppose when I was wrestling the water next out of the tight spot its in, I probably hit into it, but couldn't even see it. Thanks guys. The lights out and it seems to be running better!
