And on a sad note... this happened
Old Mar 22, 2014 | 03:58 PM
mini's Avatar
mini
Default And on a sad note... this happened
I was in the process of charging the battery after a long winter. And as I was starting it I noticed that floats where not shutting off. So I took off the front bowl, fixed the float jam and proceeded to fire. And I got a little more than a start up. Luckily everything is insured and hopefully back together soon.
Old Mar 22, 2014 | 11:11 PM
MadHatter_o0's Avatar
MadHatter_o0
wow man sorry to see/hear that!! good thing its insured.. looks real similar to my setup.. what kinda holley was that? what size jets do you use? im trying to get my new 3310 runnin right
Old Mar 22, 2014 | 11:33 PM
mini's Avatar
mini
Yeah. Its a 4150 650 double pumper and I seemed to have it dialed in at 66 in front and 74 in rear. Running a Comp 270S Solid lifter cam
Old Mar 23, 2014 | 08:56 AM
sandgink's Avatar
sandgink
My sincerest condolences. But like the Phoenix it will arise from the ashes brand new. Yours looks similar to mine, Does yours still have the spark control computer? and if not how do you handle torque converter unlock? see my post on PTU solenoid.
Post photos when the phoenix arises.
Jake
Old Mar 23, 2014 | 09:49 AM
92DakotaClub's Avatar
92DakotaClub
ah.. another dodge falls victim to a BBQ... hopefully it just looks worst then it is, looks like a awesome setup ,
Old Mar 24, 2014 | 09:57 PM
mini's Avatar
mini
It does look a lot worse than it is. thank god. its mostly smoke damage but most of it should just wash off.
And I use MSD ignition box, coil and Distributor with an 88' 727 torqueflite 2500stall.
Damaged items - Holley 650HP, 8.5mm wires, and some minor alternator wire damage and split loom melted. Haven't touched it since its still going through insurance ect.
Also in the process of building a center console anyone recommend wood or metal? I suppose wood would be easier. And I'm definitely putting in a fire extinguisher
Old Mar 25, 2014 | 09:56 AM
92DakotaClub
if your good with gel/resin, or good with foam/upholstery then wood would turns out nicely, i had built one for my 2002 dakota, quad cab and lost the center seat up front,kept the original steel frame to utilize the arm rest/storage compartment.then housed a 8 inch shallow mount kicker sub and amp hidden away aswell as a headrest dvd player modded in for daughter in rear with own speakers..... anyway used 5/8's MDF and alot of PL Premium and resin over top, sanded prepped painted, look almost original do to utilizing exsisting arm rest..
Was gonna do something similar now to my 92 but making under rear seat box is more fun and can get 2 8 inchers! then il find a factory bucket/console somewere! i seen em before!
Old Mar 25, 2014 | 06:31 PM
jockjock's Avatar
jockjock
Check out the snowdigger website, its where I got my idea for a center console, I am about halfway done it, I used the same material as him, 1x1x1/8 aluminum and 1/4" pvc, it looks great and will be nice after paint. I built it a little wider then the original so that I could hide my amplifier under it
