Swapping back to carb?
Old May 16, 2014 | 08:52 PM
pinkfloydeffect's Avatar
pinkfloydeffect
Question Swapping back to carb?
I want to swap my 88' Dakota with it's 3.9L TBI back to carb, they came with one in 87' only like this one. Can I just pull my throttle body and bolt this on good to go? Or will I need to change fuel lines and other things? Should be straight forward? Can I use a carb off anything else since the 87 Dakota carb might be hard to find? (keep in mind dirt cheap) this one photoed is $75 on eBay
Old May 17, 2014 | 12:30 AM
onemore94dak's Avatar
onemore94dak
https://dodgeforum.com/forum/2nd-gen...arburator.html
Old May 18, 2014 | 05:31 PM
shadowthedakota's Avatar
shadowthedakota
You would have to install a new fuel pressure regulator. iirc fuel injection runs at around 40psi and carbs run around 4-8 psi depending on the setup. And 318 carbs aren't a direct bolt on.
Old May 18, 2014 | 10:34 PM
pinkfloydeffect
Not worth all the work
