Codes on a 1996 dodge Dakota
Old May 24, 2014 | 04:20 PM
Jud980's Avatar
Jud980
Default Codes on a 1996 dodge Dakota
I did the cycle the ignition 3 times trick and got 12 21 21 55 could anyone give me some insite on what these codes mean? Thank you justin
Old May 25, 2014 | 09:25 AM
92DakotaClub's Avatar
92DakotaClub
https://dodgeforum.com/forum/1st-gen...d-1-codes.html
has all you need to know
Old May 25, 2014 | 10:56 AM
Jud980's Avatar
Jud980
Thank you.
Old May 25, 2014 | 11:01 AM
Jud980's Avatar
Jud980
Also does anyone know since my battery was disconnected in the last 50 key cycles will that cause it to fail my emissions test?
Old May 25, 2014 | 11:09 AM
92DakotaClub
no.... but it would need to relearn so if was just done its possible... but with O2 sensor issue that would cause emission fail
http://en.wikipedia.org/wiki/Oxygen_sensor
its a direct part of emission control, also i do beleive your truck is OBD2 so you might have 2 O2's one by manifold on close to engine and one behind the catalytic converter
Old May 25, 2014 | 01:34 PM
Jud980's Avatar
Jud980
I do have two oxygen sensors and I plan on puting new ngk o2 sensors in on Friday before I take it to get inspection and emissions done. "The ones in it are bad". Circut malfunction " to many volts" and won't read the mixture. They are original from 96 and have 225980 miles on them. I don't think that's to bad for oem stock o2s. My other ? Is what's better ngk or njk? Napa carries ngk here and advanced carries njk.
Old May 25, 2014 | 02:59 PM
92DakotaClub
NTK is most common
Old May 25, 2014 | 03:04 PM
Jud980's Avatar
Jud980
Ok thank you again
Old May 27, 2014 | 05:15 PM
Jud980's Avatar
Jud980
Well I went and got my o2 sensors today. It turns out that they are ntk so that's a plus I guess. Now if only it will stop raining long enough for me to put them in and see if my cel comes back on.
Old May 27, 2014 | 07:38 PM
Jud980's Avatar
Jud980
Update* Well it stopped raining and I put my oxygen sensors in, my Dakota has been running for around 20 minutes now and is up to temp and no check engine light so I must have done something right. I also dumped in a full bottle of fuel injector cleaner to clean my injectors. So far so good now to go get it inspected and my emissions done on it Friday.
