Fuel guage
Old Jun 30, 2014 | 03:42 PM
Hansm14's Avatar
Hansm14
Default Fuel guage
94 Dakota SLT 4x4-When my fuel guage goes to just under half empty,it drops to almost empty and then goes back up after a while.It does that several times without going to completely empty. I know there is fuel in the tank and the fuel pump is pumping fuel.It can show empty under half or a quarter full,but I know I got fuel .I had the fuel pump replaced a few years ago but for a different problem.Thanks
Old Jun 30, 2014 | 05:32 PM
92DakotaClub's Avatar
92DakotaClub
bad connection bad ground or bad sending unit, there is a thread here on how to remove and fix the sending unit.
or you can do what I did was just keep it over half a tank LOL
Old Jul 1, 2014 | 01:36 PM
Hansm14's Avatar
Hansm14
Is the sending unit inside the tank?
Old Jul 1, 2014 | 03:06 PM
92DakotaClub
yes.. its basically what fuel pump is attached too... it has a float attached to it.
your best bet would be to check grounding to it bt most of time to check the wiring to it will require taking down the tank, or removing the boxi found unbolting the box/fuel filler neck/taillights alot easier then dropping full tank of fuel
anyway this is on another forums but its from a forums member here:
http://www.dakota-durango.com/forum/...ad.php?t=73372
Old Jul 2, 2014 | 09:04 AM
kahanabob's Avatar
kahanabob
sending unit issue
Old Jul 2, 2014 | 07:32 PM
onemore94dak's Avatar
onemore94dak
There is a TSB on this. Its a factory wiring issue
http://dodgeram.info/tsb/1994/08-33-94.htm
Old Jul 22, 2014 | 05:52 PM
Hansm14's Avatar
Hansm14
How and where would you check the ground?Do you need to remove the fuel tank to check all the wiring?I haven't used my ohm meter in years.
Old Jul 22, 2014 | 06:33 PM
onemore94dak
That link from 92Dakota is good. I learned a likely reason my new pump isn't working. I think its 90 degrees off, I guess the arrow on the inside of the tank was not the direction I should have put the float in. ON the OP's final posts with pics the pic showing correct alignment isn't coming up on photobucket so right clink on the thumbnail bottom left choose view image then use ctrl and + to increase its size so you can tell what is facing what way when you look at the other pics.
If that doesn't work?
