front suspension swap ?
Old Sep 2, 2014 | 08:09 PM
dakotakid17's Avatar
dakotakid17
Default front suspension swap ?
well nobody got back to me on aftermarket front suspension for 92 to 96 4x4 daks i was wondering if anybody knew if the 4x4 suspension from 97 and newer dak would fit ?
Old Sep 3, 2014 | 07:17 PM
OMGnanerpus's Avatar
OMGnanerpus
As far as i know, a '92 Dakota and a '96 Dakota should have the same suspension. As long as they are both 4x4 or 4x2
Old Sep 3, 2014 | 08:11 PM
92DakotaClub's Avatar
92DakotaClub
from what I found.. yes google helps to answer your own questions aswell as looking on these forums is that the second gen apparently control arms etc bolt up to the first gen location but requires pretty much everything from the second gen to work form bearing hubs to balljoints to spindles to tierods basically everything ... remember the 97 and 98 second gen had differences apparently then 99-04 .. .. simple searches bring this info up, now if modifications of anykind were needed I don't know I didn't look into it..
remember when asking since you posted complaining , don't think everyone is around some have a life some work and some don't know..
Old Sep 3, 2014 | 08:18 PM
dakotakid17
sweet well then where would i be able to find tubular control arms for a 97 98 dak 4x4 ?
Old Sep 3, 2014 | 08:31 PM
92DakotaClub
its not just that tho. you need entire front clip so basically a donor vehicle ... your not catching the point you need everything ...
Old Sep 3, 2014 | 09:59 PM
Crazy4x4RT's Avatar
Crazy4x4RT
NO a 2nd gen suspension parts will not fit on 1st gen's. There is no aftermarket suspension for 1st gens. There used to be, but no longer sold. You might get lucky and find someone with one still on the shelf. See the FAQ2 for other options as well as this same info.
Old Sep 3, 2014 | 10:44 PM
92DakotaClub
i wish i remembered were i it... it was a dodge forum anyway but it was a lot of work
Old Sep 4, 2014 | 02:33 PM
93 ragtop's Avatar
93 ragtop
I can tell you I tried to use a 97 upper control arm on a 87, both 4wd. The 97 bolts up to the frame, but the ball joint has a smaller dia. stub. So you would have to change the knuckle as well, not sure what else at that point. I ended up putting new bushings in mine along with new ball joints. Kept the old arms.
Old Sep 4, 2014 | 05:43 PM
dakotakid17
i get that i need every thing i just wanted to know that it would fit before i did all the work a have hundreds of donor trucks at my disposal. thats why i was hoping to find aftermarket uppers and lowers arms for the 2nd gens but all i can find is oem aftermarket like moog etc etc
Old Sep 4, 2014 | 07:15 PM
92DakotaClub
yea not much aftermarket for the dakota's to begin with regardless on generation compared to other vehicles anyway
