Front end bushings
Old Sep 6, 2014 | 02:04 PM
marcar1993's Avatar
marcar1993
Default Front end bushings
So I've done my searching and research. Does anyone have a definitive answer to a few questions?
First, if I modify 2nd gen lower control arm bushings, only one per side is too big right? The other one works without modifying? Will the upper control arm bushings in the kit fit my truck or do I need this kit PLUS the uppers for my truck?
http://www.summitracing.com/parts/en...e/model/dakota
Anyone who has been through this before please give me any tips or tricks! Thanks.
Old Sep 6, 2014 | 05:35 PM
93 ragtop's Avatar
93 ragtop
That is correct. I am in the middle of doing mine now. Actually one side is done and back together. Almost have the other side done.
The uppers are the same part no. for 97 and 87. The lower as you said, one side fit, the other is too long. What I did was cut out the old bushing, then used the metal sleeve to cut the length of the new metal sleeve. I marked it and used a pipe cutter to shorten it. Then the poly bushings, I just used my bench grinder to cut down. Made several tries to get it exact. A little time consuming, but believe me, getting it all apart is harder then putting it back together. Good luck!!
Old Sep 8, 2014 | 02:03 PM
marcar1993's Avatar
marcar1993
Ok, thanks. You used the energy suspension poly bushing kit?
Anyone else have any experiences?
Old Sep 8, 2014 | 02:48 PM
RalphP's Avatar
RalphP
For the 2WD front suspension, I used the ES bushings and my hardest job was getting the old ones out.
The truck actually bounces "smoother" with less binding than it did with the rubber bushings, but they WERE ancient.
I had to buy a BernzAMatic propane torch to get the rubber out, and it was fun with the UCA bushings since the shaft stayed in there ... but I got it done!
Note: Due to the excessive humidity, the UCA bushings now squeak a bit. This was expected, they ARE poly ... I use some PTFE spray lubricant on them to get them to stop.
RwP
