4'' TM suspension lift problems
im working on putting the control arms on and the spacers its giving me a ton of fits the studs and nuts they provide i cant seem to get them to work and are having to go with a shorter slotted nut i was just wondering if anybody else that has installed this lift ran into any problems in this area
a new problem has come up now the sidewall of my tires is rubbing on my upper control arm and not sure exactly what spacers to get since i just bought the new wheels dont have a picture right now but im looking to go with
4.5 don't cut it... sorry .. the instructions that originally came with it specify 3.75 backspace but 4 does work
if you had bigger rims 4.5 would work but I believe would require 17's or so ...
also width of rim has an effect on width of tire...
Trending Topics
the instruction that come with it say 4.5 min
page 2 .3 http://www.autotrucktoys.com/pdf/TMDD43.pdf
and yes i know the width affects it also but i didnt put the 2 together
actually the trailmaster install manual says maximum backspace cannot exceed 4 1/8th and distance from rim/hub mating surface to edge of tire cannot exceed 4 3/4 inch
Now this is the Manual that should have came with the lift kit unless it was missing ...
Source (CrazyRT's private collection)
anyway the spacers u posted are good I had a set of 1.5's and 2.0's and well made just make sure you use the supplied nuts to mount to truck as truck ones might be to long to fit between spacer and rim
that PDF is the exact one that came with the kit and it still says
Wheel Change Necessary: Maximum back space of rims
cannot exceed 4-1/2". Fig. 1. Distance from rim/hub mating
surface to inner side wall of tire cannot exceed 4-3/4". Fig. 2.
Ensure rim and tire combination you choose provides
adequate clearance between tire sidewall and upper control
arm.
but thanks though
arm.
but thanks though
