Sure Grip
Old Dec 14, 2014 | 11:56 AM
dobaroy's Avatar
dobaroy
Default Sure Grip
Looking for a company somewhere in Michigan that sells the Sure Grip units, if anybody has a lead for me, that would be appreciated. Thanks
Old Dec 14, 2014 | 12:08 PM
tbugden's Avatar
tbugden
Sorry, no leads on the sure grip. I know RockAuto has some trac loc diffs for the 8.25 axle if you're interested in that. Good luck.
Old Dec 14, 2014 | 02:00 PM
moe7404's Avatar
moe7404
i have a 01 dak 3.9 V6 auto trans. stock came with a 3.55, open rear, 8 1 / 4. way under powered. so i say to me if i dont have MPG ill just get power. i had a 4.1 Motive Gear C8.25-4.10 gear put in and a DANA / SPICER LOCKER 84852. in 2011. my MPG went from 8-9 to 11-12. cause the O,D. comes in at 30 MPH. the trans thinks its going faster than it really is. and the speedo did NOT need reset. BUT i drive only in town. but my paper factory service manual call it a TRAC-LOK. my 1967 factory coronet manual calls it a 'sure-grip diff'.
Old Dec 15, 2014 | 07:03 PM
dobaroy's Avatar
dobaroy
Thanks guys, and moe, if I may ask, where did you get your hands on the 4.10. I would think the speedo would have to be out a bit going from 3.55 to 4.10, cause a long time ago we changed a Dak from 3.55 to 3.9 and we actually had to change the speedo gear.
That must have made your truck nice and fast!
Old Dec 15, 2014 | 09:33 PM
Tom A's Avatar
Tom A
Section Moderator
It depends on where the speed sensor reads. If it reads the tone ring on the ring gear, then changing gear ratios won't make it read any differently. If it reads off the transmission or transfer case output, that's a different story.
Old Dec 16, 2014 | 02:17 PM
dobaroy's Avatar
dobaroy
Thanks Tom for that bit of information, didn't know that, usually only work with older vehicles and sometimes when we swap gears it is difficult to get the speedo to read correct.
Old Dec 16, 2014 | 10:13 PM
Tom A's Avatar
Tom A
Section Moderator
No problem. In this particular instance, I'm not sure exactly which speed sensor drives the speedometer (or if you even have more than one), but I'm guessing it's the one on the tailshaft housing.
Old Dec 17, 2014 | 08:22 AM
dobaroy's Avatar
dobaroy
Tom, if memory serves me right, you are correct on the position of the speed sensor. So if that is the case, do I understand then we would have to change the speedo gear?
Old Dec 17, 2014 | 08:43 AM
Tom A's Avatar
Tom A
Section Moderator
Yes, but it's super easy. Takes 5 minutes.
Old Dec 18, 2014 | 06:32 AM
ZING69's Avatar
ZING69
I think your looking for dr diff. Try f0r a-bodys only fourm or try dr.diff.com good luck
