gage compatibility
Old Nov 10, 2015 | 09:11 AM
RalphP's Avatar
RalphP
It looks like a good adapter, but I've never tried it.
I'm looking at the adjustment on the tach board and am about to play with it to see if I can get it to work right on a V6.
For the V8, you can cheat some - a /2 flip flop will work to get you 2 pulses per revolution. (There's not a simple 2/3 flip flop available, alas.)
RwP
Old Nov 10, 2015 | 09:18 AM
93 ragtop's Avatar
93 ragtop
Ralph, just to update this, I just sent Dakota digital an e-mail asking the following question. If you don't mind reading it, and correct me, if I mis-represented this situation.
Thanks
I have a question concerning the SGI-8E tach adapter. I want to adapt a tach out of a 92 dodge Dakota to run with a standard HEI system. At first I will be running a v6 motor, then later a v8 motor. I will have a neg. coil terminal to tie into. Also, it is my understanding the factory tach in the 92 dodge Dakota is designed to see 2 pulses per revolution, this is regardless of motor size. Will your tach interface work in this case?
Thanks
Old Nov 12, 2015 | 08:42 AM
93 ragtop's Avatar
93 ragtop
OK I got a answer back from Dakota digital. Below is the answer
Richard,
The SGI will do what you want it to so that the tachometer works again. It might take some dialing in but it will work.
Best Regards,
Josh Kobernusz
Old Nov 12, 2015 | 08:44 AM
93 ragtop's Avatar
93 ragtop
Now, I need to start searching for a 92 dash schmetics. I have a FSM for my 87. If its not too difficult, I may pickup a 92 instrument panel and try.
Old Nov 13, 2015 | 07:19 PM
DukeDomB's Avatar
DukeDomB
I have the 92 FSM and have recently done some instrument cluster work... I can help you with this if you need anything. Just let me know.
Old Nov 13, 2015 | 10:40 PM
RalphP's Avatar
RalphP
Can I get a copy of the cluster connectors, plus a copy of the cluster schematic?
Or a copy of the entire 8W section? *grins*
RwP
Old Nov 15, 2015 | 02:25 PM
93 ragtop's Avatar
93 ragtop
I sent you a pm with my email address. If you could help I would appreciate it.
I mainly would like to see a diagram of the printed circuit board connectors.
Thanks again for offering to help!!
Old Nov 15, 2015 | 10:49 PM
DukeDomB's Avatar
DukeDomB
Check your email bud!
Old Nov 16, 2015 | 08:38 AM
93 ragtop's Avatar
93 ragtop
Thanks for taking the time sending me the pictures!!
That was exactly what I was looking for.
Now FWIW here are my plans. Pick up a 92 dash with gages. Now I currently have what is called a 87 dash with gages.
So hopefully with your diagram and my orig. 87 diagram "both below" I will be able to re-pin the connectors and then use the Dakota digital tach adapter to wire up the tach.
Hopefully the connectors are not too difficult to get the pins out of.
Again ,thanks for your help!!
87 connector diagram
92 diagram
Old Nov 17, 2015 | 08:52 AM
93 ragtop's Avatar
93 ragtop
OK, I found a 92 dash out of a 5.2 truck on ebay. Ordered it. Will update after it comes in.
