what year went electronic transmission?
Title says it all. Trying to find out if a 96 v8 4wd transmission is hydraulic or electronic controlled. Its a early model (9-95) Its not where I can look at it, at this time.
Edit to add, its an automatic.
http://www.*********.com/forums/showthread.php?t=275952
its 318 and Crazy posting it on another forum lol
some reason it wont let me post other forums website? argh....the ****** are d o d g e t a l k <-- wont even let me post that wth
the 96 was first with the RE(electronic) with OBD2 .. all previous years were RH(hydralic)
From 95_318SLT the switch was in '96 when they switched to the OBDII computer. The difference is it went from a hydraulically controlled governor valve to an electronically controlled governor valve. Now if you're in desperate need for a transmission and all you can find is the rh, they will work fine (but might trip a CEL), but the re cannot be backtracked cause the old computers can't control
Yeah even though it's an RH transmission, the upshift and downshift into and out of overdrive (3-4 upshift and 4-3 downshift) as well as torque converter lock and unlock are electrically actuated by solenoids under the control of the engine computer (SBEC)
