Will this motor work?
Old Jan 31, 2015 | 09:08 AM
OMGnanerpus's Avatar
OMGnanerpus
Default Will this motor work?
I have a 93 3.9l 4x4 and someone i know is selling a 5.2l and tranny out of a 93 d150 4x2.
Will the engine and tranny bolt up, or will i have to play around with it?
Old Jan 31, 2015 | 09:17 AM
You will have to play around with it.
Old Jan 31, 2015 | 01:36 PM
OMGnanerpus
Do you know with what exactly? I'm assuming mostly tranny to transfer case because the dak is a 4wd and the donor is a 2wd.
The engine should bolt right up to the motor mounts. I'd have the computer and wiring harness from the donor
Old Feb 1, 2015 | 10:07 AM
92DakotaClub's Avatar
92DakotaClub
from my understanding you cant remove the tailhousing off some 2wd transmissions so making the 4wd impossible, this is something i would check first
Old Feb 2, 2015 | 08:53 AM
93 ragtop's Avatar
93 ragtop
I agree. Also, check where the shifter comes through the floor. No experience with it yet, but my understanding the Dakota has a different shifter location. I think the ram series puts the shifter further under the dash.
