No Start Compression Issue
Old Jan 31, 2015 | 06:33 PM
i_da_bomb00's Avatar
i_da_bomb00
Default No Start Compression Issue
1995 3.9L
One day while driving it, the truck suddenly died. There is fuel and spark. I replaced the timing set (the chain had been flapping for some time) thinking it was a timing issue. The cam gear was nearly bald on one side.
Put it back together, no start. Checked the spark today and it tested fine. Testing the fuel I did the ole spray gasoline in the intake method.
Still no start but I did notice something odd, there is no vacuum at the tb!! I immediately did a compression test and ALL CYLINDERS have NO compression, the crank turns really easily. What in the world can cause this??
Old Feb 1, 2015 | 03:08 PM
Thomas_kota's Avatar
Thomas_kota
For all cylinders to not have compression all of a sudden? I can only think valve timing... Do you typically drive it hard? When it died was it just like key off or did it make noise?
Old Feb 2, 2015 | 09:00 AM
i_da_bomb00
It sputtered, rpms went down then suddenly it was off. I put the timing kit in myself, I witnessed the two dots line up. The only thing there is the crank is 180 out but would that make a difference? I'm wondering if it jumped out of time and bent the valves?
