LA accessories on a magnum engine
Old Jan 31, 2016 | 04:57 PM
93 ragtop's Avatar
93 ragtop
Default LA accessories on a magnum engine
I was wondering about the advantages and disadvantages of converting the magnum accessories, (ps, ac, alt. ) to LA style accessories.
I have seen the hughes snout adapter for the cam, and Im thinking with this, I could use my 3.9 liter accessories off of my truck now. This would allow me to go back to a mech. fuel pump and I think the placement of the accessories would fit under the hood better.
I plan to run the edelbrock intake with a 670 street advenger carb. (the carb I already have) and probably a standard mopar electronic ignition.
Is it as simple as getting the snout adapter and the 87 accessories bolt up to a magnum engine?
Am I missing something here?
Any input on this project would be appreciated.
Old Feb 2, 2016 | 07:55 AM
93 ragtop's Avatar
93 ragtop
Wanted to add a link to this balancer. http://professional-products.com/har...armonic-damper
I think with this and the hughes camshaft adapter, everything from the 87 Dakota should bolt up to the 5.9 magnum.
I need to look at what basically moving everything about 4in forward is going to do, ie. AC lines etc.
Still would like to hear from others on this.
Old Feb 2, 2016 | 11:32 AM
RalphP's Avatar
RalphP
I'd look for the Shelby V8 parts from 1989 and 1990 to use for things like A/C and what not.
Part numbers can be found from the parts lists on this forum, for instance.
The main thing is the lack of depth between the front of the water pump and where the radiator sits - the Shelby team had to put an electric fan in front of the radiator to make it fit (and take off the mechanical water pump.)
I'd use a single harmonic dampener instead, if it were me. For instance, the ATP for a 1988 5.9 can be had for under $70 ( http://www.rockauto.com/catalog/rafr...&parttype=5512 )
RwP
Old Feb 2, 2016 | 05:47 PM
93 ragtop's Avatar
93 ragtop
Ralph, thanks for your input. I plan to sandwich dual fans in between the condenser and the radiator.
As far as the balancer goes, I cant use the 88. The 5.9 LA and 5.9 magnum have different balancing. The professional products unit is supposed to come with the different weights, based on what motor is used.
Thanks again.
