Issues on switch to carbed engine Dakota
Old May 20, 2016 | 02:39 AM
ILuvYahuah's Avatar
ILuvYahuah
Question Issues on switch to carbed engine Dakota
Thinking of switching from fuel injection to carburetor. Would that be wise?
Old May 20, 2016 | 03:08 AM
RalphP's Avatar
RalphP
First off, why?
IMO, no - better to fix any current problems. I mean, what does carburation give you for street driving, besides the fun of fiddling with something that can break when you look at it cross eyed?
Not to mention, replacing the distributor, rewiring the engine bay, fixing the gauges, etc.
RwP
Old May 20, 2016 | 11:17 AM
robertmee's Avatar
robertmee
Originally Posted by RalphP
First off, why?
RwP
I'm going carb on my 360 swap...cars have been running carbs reliably for 70 years...I like old school, clean engine bay, no computer, etc. Yes fuel injection is less temperamental and if it's your daily driver I'd probably stay with it for the mpg. But if it's your fun knock around truck like mine, nothing wrong going carb.
Old May 20, 2016 | 02:22 PM
RalphP's Avatar
RalphP
True dat, Robertmee.
However, that also presumes a whole new wiring harness.
(I've done carbs, I've done EFI, I'd rather fiddle with EFI tables than tune a carb, but that's me. That, and having air/fuel and spark both under the control of the same ECU makes it a LOT easier to swap the parameters around for a desired performance target than having to fiddle with both ... add in an electronically controlled transmission, and now you can also control shift points etc.!)
Besides, with full control, you can go COP, which cleans up the engine bay; tuck the wiring under/into the fuel rail/fuel rail covers, and that's dressed up; there's not really THAT much more wiring if you do EFI right.
RwP
Old May 22, 2016 | 03:24 PM
93 ragtop's Avatar
93 ragtop
You don't mention year or motor you have.
Assuming its a V6 one of the problems is finding a distributor that will work. The v6 fires in a odd way. The reluctor is set at 116degrees then 124 degrees. Not an even 120. Chrysler used to make a distributor to work with that but it was disc. years ago. And as most know the aftermarket support for the v6 is almost non existent.
Again, with the intake, what year? and even at that, other the the 87 none were designed for carb. FWIW I think the 87 will work on the 88-91.
Now if you have a 5.2 V8 it will be much easier.
