p/n safety switch ground
Old Apr 29, 2017 | 03:25 PM
robertmee's Avatar
robertmee
Originally Posted by RalphP
If the PCM is being removed, but if you still want lockup and overdrive, there's always the method used by PATC for their 727/518 upgrade kit ..
https://transmissioncenter.net/shop/...iring-diagram/
RwP
Yep...exactly what I used.
Old May 4, 2017 | 07:27 PM
volaredon's Avatar
volaredon
ut the middle ire from the neutral safety switch plug. Put a terminal on the end and ground it. Done. those years the computer doesnt really care if the truck has an auto or a stick in it. and yes you might still get a code 37 anyways, with a stick it would be known as a "false" code' Won't trip the check engine lite.
