Charging Issue - Code 41
External regulator fixed it. 14.3 beautiful volts at idle
thanks for all the quick responses, I'm still learning this truck lol
Now Is there a way to get rid of the 41 code even though the ECM voltage regulator is disconnected? I'm assuming no but I figured I'd ask lol
Thanks again!
Thanks again!
Besides replacing the ECM, that is.
RwP
New update (not the good kind)
Had to jump it to get home today. Checked voltage when I got home and the regulator I installed yesterday that was giving the battery 14v is now giving 12v. I also replaced the battery yesterday so it is brand new as well.
Do these regulators come in different sizes or something? Was mine too small and it fried? The one I installed was from Autozone, part # VR733
Thanks
Thanks
Thanks
Thanks
Edit to add....Also, when regulators fail, they almost always open up, allowing the alternator to overcharge at 16 to 18Volts. Thinking you have something going on beside a regulator.
Charge up your battery, and disconnect the alternator from battery and voltage regulator from alternator
Crank Engine
Check voltage at alternator + Terminal and Ground, and + Terminal and Battery -...These should match and be above 14V...If no voltage or weak voltage, increase idle to see if voltage goes up...could be a pulley mismatch or slipping belt if you changed alternators.
Turn off Engine, Connect voltage regulator
Do the same as above. See if Regulator is limiting voltage.
Well I got the regulator swapped under warranty and hooked it up. Back to around 13.5v from the + post on the alternator.
I have the Bosch model alt with the dual pulley (90 amps I believe, I at least know the other option which is the Denzo is the higher output)
So I'll run it and see what happens. I did notice that the first regulator was very hot to the touch where it was mounted on the firewall. This one has been relocated to a cooler location at the inside of the fender beside the battery. We'll see
I've replaced the battery, alternator, and the regulator. All fuses and wires are good. What else should I check? I thought those three components pretty much made up the entire charging system
