Leveling the rear to match the front
Howdy folks, I've got a 1992 Dakota LE. I've been all over this site and a few others. I can not seem to figure out how to bring just the backend down to match the fronts stock height. I don't want to do blocks because i want to maintain a somewhat decent ride and not bounce all over the road.
Everyone seems to be saying swap your leaf springs under your axle and get longer shackles to achieve this. My leafs are already under the axle and the shackle seems to be going the opposite direction than everyone elses and longer shackles would actually lift the rear end more.
Am I looking at this wrong? Any help would be greatly appreciated.
Duh! Leveling! This site doesn't have stuff for the 92 LE but the link will show you what you are looking for.
http://www.sdtrucksprings.com/leveli...s/dodge/dakota
Found this- Coil Spring spacers http://www.jcwhitney.com/pn/c11312p2...d=d412y1992g23
Is your truck 2WD or 4WD?
If 2WD, easiest is to use blocks between the springs and the axle. It should not take much; that will also not cause the truck to bounce all over the road (that's usually an artifact of a 4WD being RAISED on blocks).
If 4WD, well, first shot would be to swap to a 2WD rear axle; that'll drop the back something like 2" just by slinging the axle OVER the rear springs (2WD) instead of UNDER the rear springs (4WD). (You can also have the spring seats cut off and rewelded if yours is 4WD; that has the advantage it keeps the front and rear diffs at the proper ratio.)
RwP
RwP
Trending Topics
