Parking lights shorting out somewhere
My parking lights and plate lights stopped working the other day, but my headlights and blinkers still work fine. I found the fuse was blown in #8, and when I replaced it, it blew again as soon as I pulled the switch. I just put a new light switch in earlier this year and redid the wire ends that are plugged into the switch, and I checked them last night and they still all look fine with no exposed areas. Are there any problem spots I should check for corrosion first before going from each light to the source?
Also, don't forget the wig-wag lights at the front corners if it's an early Gen1 (does not apply for the later Gen1s that don't use the 194 in the corner as a wigwag light.)
But yah, pull all the bulbs, see if it blows again. If it does, then it's in the wiring; if not, then it's a bulb.
Opinion: If you've ever thought about going LED, now would be a good time, although you should also change the flasher modules if you do go LED.
RwP
No; but first I'd pull the bulbs and make sure a BULB isn't shorted inside, especially if they're incandescents. If it blew, and the blown filament fell just right, it may short one.
RwP
RwP
So, scratch "early Gen1" and say "all Gen1".
*goes check wiring in the FSM for a 1995, yep, single bulb in the wigwag configuration*
Thanks for the correction.
RwP
Thanks for all the suggestions. I finally found it today, there was a bare wire on one of my cab lights. I put those on a separate fuse so if they go again I'll still have the rest of the lights I need to drive at night. I do want to go LED though, you guys have any suggestions for LEDs that don't cost an arm and a leg? I've had very hit or miss luck with cheap Amazon lights. It's crazy how old led technology is yet advance auto is still trying to get $25 for two of them
That said - I've got a set of these in the back of my 1988 right now.
Or the 3157 in the back of the Cougar, I forget which offhand.
BOTH of those are nice and bright on brake and are still very visible on parking/tail lights.
RwP
