no power to radio/cassett player or clock
Old Sep 28, 2017 | 04:05 PM
Dale Hidy's Avatar
Dale Hidy
Default no power to radio/cassett player or clock
I parked my truck went back 2 days later, all is well except i have no clock or radio. Checked fuse and it is fine. I have 12vdc on the orange wire going to the radio when acc or in on mode. I do not know where to look and can not find the wiring diagram for the stock radio/cassett player
Can you guide me to something? I have 35 years exp. as an electronics tech so i will understand
Old Sep 28, 2017 | 04:19 PM
onemore94dak's Avatar
onemore94dak
The 95 FSM in the FAQ page has the wiring diagrams in chap 8W.
You can peruse this site. It has fixes for radios maybe it has the wiring harness? https://www.allpar.com/stereo/combo-deck/
Old Sep 28, 2017 | 04:23 PM
RalphP's Avatar
RalphP
Here's something that's not immediately obvious without decent wiring diagrams - the ground is through a metal strap from the radio to the dash support.
Do you have the ground strap on it? If not, then you'll have no radio.
RwP
Old Sep 28, 2017 | 04:29 PM
Do the dome lights come on when you open the doors?
Old Oct 2, 2017 | 06:09 PM
Dale Hidy's Avatar
Dale Hidy
Pulled the unit out for inspection. Ground strap is secure on both ends and no signs of corrosion.
Old Oct 2, 2017 | 06:10 PM
Dale Hidy's Avatar
Dale Hidy
no interior lights come on
Old Oct 2, 2017 | 07:16 PM
Check the IOD fuse.
Old Jan 12, 2025 | 09:57 PM
kotakief's Avatar
kotakief
Check the IOD fuse.
what fuse is that? I have an 89. No radio no interior lights. Fuse 14 no power
Old Jan 13, 2025 | 09:26 AM
Start your own thread, tell us what you are driving, what the problem is, and what troubleshooting you have already done.
Old Mar 2, 2025 | 01:41 PM
olphrt88's Avatar
olphrt88
The IOD fuse is in the power distribution box, if it is blown, no radio.
