Is there an Arcive on OVERHEATING issues?
Old Oct 20, 2017 | 10:29 PM
Got a cherry picker? Works great for moving around large, heavy objects, that you need someplace other than where they are at.
Old Oct 20, 2017 | 11:21 PM
CocaColaDodge's Avatar
CocaColaDodge
That is a good idea, but I had a better one. Told him I would start charging him the same fee as a storage unit if he doesn't have them out of the way by Wednesday (his next day off).
Old Oct 21, 2017 | 09:38 AM
LOL. Yeah, that works.
Old Oct 21, 2017 | 09:46 AM
robertmee's Avatar
robertmee
Originally Posted by CocaColaDodge
Thank you for all for the input and ideas, and yes I do have the fanshroud on. I'll most likely get a new thermostat and temp gun when I finish the cylinder pressure check, but again I have to wait for that until these motorcycles get moved out of my polebarn (he locked the steering on them).
FYI you don't need a cylinder tester.....go to Advance Auto and rent their combustion tester....also referred to as block tester. It's just a simple siphon tube that pulls your fluid into a test tube and chemically tests for combustion gases mixing with your coolant. The tester is free to rent. You'll need to buy the $10 bottle of testing fluid. But it works great and will tell you if you have any issues with a head gasket allowing combustion into the antifreeze.
Old Oct 21, 2017 | 12:00 PM
93 ragtop's Avatar
93 ragtop
Smile
I believe that is what is referred to as TOUGH LOVE!!
Old Oct 21, 2017 | 02:48 PM
CocaColaDodge
Yeah, there is no way I would actually charge him, but I do need to have them moved by Wednesday though.
Old Oct 21, 2017 | 03:15 PM
tomdel45's Avatar
tomdel45
not sure how to start a new question but here it goes i have a 1997 dodge ram 1500 4x4 pick up. on the front brake line that goes from the right to the left, i see on end goes to the break but can not find where the other side goes to
Old Oct 23, 2017 | 02:19 PM
CocaColaDodge
Typically it follows the firewall behind the engine and above the transmission up to the master cylinder or splitter block.
Old Oct 23, 2017 | 04:22 PM
onemore94dak's Avatar
onemore94dak
Default New Threads
You look on the main page of the section you want to be in and near the top left is a button to select a new post8ing. You want to be in the Ram section not the Dakota section. At the very top there is a Forums drop list hover then select Dodge Trucks then Ram
