new update on 3.9 blown head gasket
Old Nov 26, 2005 | 01:50 AM
92dakotasport's Avatar
92dakotasport
Default new update on 3.9 blown head gasket
well after getting the motor apart and relapping the valves i noticed a hair line crack inbetween the intake and exhaust valve so im either looking for a set of heads or going to drop in a 318
I have my hands on a 318 but i was told it was a wide bore 318 ? i never heard of that so any info on it would be great
Old Nov 26, 2005 | 04:24 AM
injmopar's Avatar
injmopar
Default RE: new update on 3.9 blown head gasket
Do you mean the old poly 318. Does it have a cast iron waterpump.
Old Nov 26, 2005 | 11:26 AM
92dakotasport
Im not sure im going to have to look at it again its my father in laws truck when he found out the head was cracked on my 3.9 he offered the 318 to me
Old Nov 26, 2005 | 06:45 PM
92dakotasport
come to find out its not a cast water pump the motor is from between 1974 - 1978
Old Nov 27, 2005 | 05:01 PM
360DakotaPwr's Avatar
360DakotaPwr
If you have a 92 like your name inplies then the magnum fuel injection stuff might not work well on that motor. Any questions on the 92 up stuff about v6 to 8 swapping, I would be more than happy to help.
Old Nov 30, 2005 | 08:53 AM
92dakotasport
the 318 is not fuel injected its still has a carb he bout new for it 2 years ago new water pump last year very well mantained motor oil changed every 3 months even if he drives it just once
i was told the 3.9 was the same block as the 318 minus two cyclinders ? is that correct ?
Old Dec 1, 2005 | 02:06 AM
injmopar's Avatar
injmopar
Unless you have a welder or want to pay $400 for custom mounts a 78 will not just drop in. You are right there is no wide bore 318.All 318 have the same bore spacing. They were thinking of the old big block 318, and you would not mistake it for a 74-78. The magnum motors mounts are between the 2nd and 3rd cylinder from the back of the block.So a 92 and newer 318 or 3.9 bolt in with no extra parts.
Old Dec 2, 2005 | 12:52 PM
360DakotaPwr
Yup, three bolt hols that forms a triangle.
