What are these vents for on my 1995 Dak?
Old Oct 30, 2017 | 01:35 AM
BlueLiner's Avatar
BlueLiner
Default What are these vents for on my 1995 Dak?
While taking my cowl off to paint some areas and prevent them from rusting, i noticed two identical holes right below the windshield on each side of the truck. Originally there was a small 2 inch by 2 inch mesh with a drywall stucco material that was covering the hole. The mesh material appeared to be oem. I removed both from each side due to their deterioration and have no clue as to what purpose these two holes serve. Id like to cover them with silicone unless they are used for a breather of some sort? I have attached a picture for reference. Thank You!
blueliner
Old Oct 30, 2017 | 07:15 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I believe it is the outside intake for the blower motor (AC/Heater). Best to put back the screen.
Old Oct 30, 2017 | 10:04 PM
BlueLiner's Avatar
BlueLiner
Oh boy. That might be a problem. The screen was basically a square piece of cloth with some type of plaster material that was completely deteriorated hence why i removed it.
Old Nov 1, 2017 | 12:19 PM
onemore94dak's Avatar
onemore94dak
Take a look in the 95 FSM on the FAQ page. Your pictures are too close up for me to see clearly what exactly you are focused on. Anyway there are a lot of holes in the diagrams and there is a screen and seal part in the diagram as well. Chapter 23 page 7 and 8.
Old Nov 1, 2017 | 08:20 PM
BlueLiner's Avatar
BlueLiner
I took a cpl other pictures for some clarity.
What it looks like
Where it was positioned
Old Nov 2, 2017 | 07:50 AM
Did you add the black tar looking stuff or was that already there? Could these be vents to equalize pressure in the cab when you shut the doors?
Old Nov 2, 2017 | 08:36 PM
RalphP's Avatar
RalphP
The vents to EQ the pressure on a door slam are in the doors themselves, at least in the early Gen1's.
RwP
Old Nov 4, 2017 | 02:22 AM
BlueLiner's Avatar
BlueLiner
The black paint is POR15. Still have no idea what to cover the hole with.
-- blueliner
Old Nov 4, 2017 | 12:13 PM
onemore94dak
-- blueliner
Find a restoration shop and ask them? my other idea was to get some good quality nonmetallic fine mesh screen materiel and silicone caulk it in place.
