My truck loves dirty oil!
Old Dec 4, 2017 | 03:11 PM
smokin1994's Avatar
smokin1994
Default My truck loves dirty oil!
I just now picked up on this...After an oil change my 94 3.9 will smoke a lot, mainly on start up, and prolonged driving.
Last oil change was at 4k after 8 months.
Engine has 205k
Old Dec 4, 2017 | 10:02 PM
What weight oil are you using? Standard, or synthetic?
Old Dec 5, 2017 | 07:18 AM
smokin1994's Avatar
smokin1994
Conventional 5w-30
Old Dec 5, 2017 | 12:56 PM
You want to put 10W30 in there. 5W is too light.
Old Dec 5, 2017 | 01:13 PM
RalphP's Avatar
RalphP
This.
Shucks, on my 1988, it calls for 15W40 for temps up from 10*F up; 10W30 from 0 to 100+, and 5W30 only if you're dependably below 0F.
(In Louisiana, I run 15W40 year round; again, see Louisiana. If you live up in the Rust Belt, your viscosity will vary.)
RwP
Old Dec 5, 2017 | 01:22 PM
93 ragtop's Avatar
93 ragtop
There are a lot of possibilities. I would start with parking on level, let set 30 min. or so, and check the oil level. Make sure its not overfilled. Then as said above, use 10-30 or whatever the thickest oil you can use for your temperature conditions. After that, check for blown plenum gasket, bad pvc valve, bad valve seals, and run a compression or better a leak down test. But at 205k miles, and 24 years old, I would think some oil useage is not out of line.
Old Dec 5, 2017 | 08:31 PM
smokin1994's Avatar
smokin1994
I agree with you guys...I wish I could run a 20w-50 in it! But the winter needs 5w-30.
Seems to have lower end noise as of late.
