Vibration: 88 Dakota 3.9 2WD
Old Dec 8, 2017 | 08:35 AM
Josh89Griffin's Avatar
Josh89Griffin
Default Vibration: 88 Dakota 3.9 2WD
I just had the u-joint at the transmission, the u-joint at the rear end, the driveshaft support bearing, & the rear pinion seal changed on my 88 Dakota 3.9 2WD changed yesterday. Last night, I noticed while driving at 60-65MPH, there was a vibration.
I was told that maybe the driveshaft was "unbalance". Any suggestions?
Old Dec 8, 2017 | 10:38 AM
Was the vibration present before the parts were changed?
I really hate two-piece driveshafts...... they can be a pain to get installed properly, so you DON'T get that vibration.
Old Dec 8, 2017 | 11:51 AM
Josh89Griffin
After the parts were changed
Old Dec 8, 2017 | 11:52 AM
In that case, I would go back to the shop that did the work, and have them take a look.
Old Dec 11, 2017 | 11:00 AM
Josh89Griffin
My mechanic is saying its a bad transmission mount. The transmission mount is causing the driveshaft to not be properly aligned.
Old Dec 11, 2017 | 11:42 AM
Possible. Relatively cheap in the over all scheme of things..... Worth a shot I suppose.
Old Dec 13, 2017 | 04:08 PM
Josh89Griffin
Had the transmission mount changed and I changed the left rear tire. There is still a vibration when you get up to 55MPH and over. Any other places that I need to look?
Old Dec 13, 2017 | 04:17 PM
Feel it thru the steering wheel, or the seat? rotate the tires, still the same?
Old Dec 13, 2017 | 04:23 PM
Josh89Griffin
Feeling it thru the seat. I may see about getting the tires rotate & balanced.
