random shut off
Old Feb 5, 2018 | 10:25 AM
sepulvd's Avatar
sepulvd
Default random shut off
I am trying to figure out what's going on with my 92 dodge Dakota. its 4x4 318 v8. every morning it dies at the same location 1 mile after I start driving. I hit the brakes and it stalls out. it takes a couple of cranks for it to start and then it misfires for a bit at 800-1200 rpms. it runs incredible after it stalls out. any ideas would help so I don't throw a bunch of money it.
Old Feb 5, 2018 | 03:05 PM
Disconnect the O2 sensor, and see if the problem goes away. (it will set a code.....)
Old Feb 12, 2018 | 04:18 PM
FFEMTC's Avatar
FFEMTC
Before doing that, check fault codes:
http://www.allpar.com/fix/codes/index.html
Old Feb 14, 2018 | 06:17 PM
sepulvd's Avatar
sepulvd
I currently have no fault codes. am debating if its my fuel pump or iac. because once it gets warms it runs perfect
Old Feb 15, 2018 | 09:28 AM
sepulvd's Avatar
sepulvd
I don't have a check engine light on but I will do the test today after work to double check. for some reason I think its my a fuel pump and am losing pressure but once I get it running it runs like a champ so am not sure. I disconnected my IACV and the car did not run at all.
Old Jan 23, 2024 | 04:15 PM
MtnTow's Avatar
MtnTow
Done a compression test lately?
this reply was for a different post. Not sure how it got here. Sorry.
