"Y" pipe
Old Feb 25, 2018 | 11:10 AM
s/w theo's Avatar
s/w theo
Default "Y" pipe
Who makes a good low restriction "Y" pipe for a 95 5.2l reg. cab Dakota, at a reasonable price? I don't want one w/the compression bends. I want to keep it emissions legal if possible. Should bolt-up to stock location. Any one make these or should I have an exhaust shop make one. I plan on putting shorty headers on in the near future. Thanks
Old Feb 25, 2018 | 11:25 AM
RalphP's Avatar
RalphP
JBA sells one, but I'm not 100% positive it's mandrel bent.
Here is Summit's listing for it: https://www.summitracing.com/parts/j...iew/make/dodge
It says 96+, but the main difference seems to be that Walker and others show a pre-cat in the factory Y pipe for a 95; this does not. (See if yours has that swelling on it also; my 1988 doesn't with the factory Y pipe, but all the aftermarkets show a precat.)
The Walker that is a 100% direct fit is compression bent.
You may be able to get the shop to make one to fit if they can mandrel bend; if you don't go for JBA shorties or a fit-identical, that's probably what you'll have to do anyway.
RwP
Old Mar 4, 2018 | 03:04 PM
volaredon's Avatar
volaredon
just had the stock (and original) one off of my 92 as I just got done swapping the original trans out of it with 203K miles on it.... that one has a true 3" outlet, definitely bigger then the one on my '96.
Old Mar 4, 2018 | 06:20 PM
RalphP's Avatar
RalphP
Yep; 92/93 were 3", 94 and up were smaller.
RwP
Old Mar 8, 2018 | 02:39 AM
DAHEMIKOTA's Avatar
DAHEMIKOTA
If you are planning on putting on headers, I think they still come with a low restriction cross over. Mine did. I got them from Mopar Performance.
