Rust removal
Old Apr 21, 2018 | 12:00 PM
Azboyinmi's Avatar
Azboyinmi
Default Rust removal
Built an electrolysis tank. Using it to do all the rear frame cross members. Here's a pic of the setup
Old Apr 21, 2018 | 03:58 PM
onemore94dak's Avatar
onemore94dak
Freaking Awesome!
Old Apr 21, 2018 | 07:39 PM
Azboyinmi's Avatar
Azboyinmi
So far it's been 8.5 hours. I pull the electrodes about every 2 hours and hit them with a wire brush real quick. Part was ridiculously rusty. Here's a pic after 8 hours
Old Apr 21, 2018 | 11:40 PM
ragged89's Avatar
ragged89
Looking good. I just "electrolyzed" the steel trim piece above the windshield on my convertible Dak. Only thing I did on the clean half in the picture was knock the black oxide off with a scotchbrite pad; it came off easy. It was fairly rusty so there was some pitting, but after treating to some metal prep I primed it and filled the pits with spot putty. It came out nice after sanding and a few coats of paint.
Old Apr 22, 2018 | 12:49 AM
Azboyinmi's Avatar
Azboyinmi
Go to your local hobby shops or look around online for some pure zinc bars or sheets, then do the electrolysis in reverse. If you use the link bar as your negative then your carpart as the positive you can actually zinc plate your part
Old Apr 23, 2018 | 05:04 PM
Azboyinmi's Avatar
Azboyinmi
Default Update on electrolysis tank.
Dang tank is working great. Had to go pick up some more washing soda from Ace hardware. I've got the last crossmember in the tank now. Here's the first crossmember I did, this is after tanking it, and repairing the bad spots.
