Terminals and clips
Old Aug 16, 2018 | 07:01 AM
93 ragtop's Avatar
93 ragtop
Default Terminals and clips
Below are pictures of the wire terminals and clips used in a 92-93 underhood relay panel.
I know this is a long shot, but does anyone know of a source for these other then the junkyard?
And if a junkyard is the only choice, any idea how common they are, ie: years used, models used etc.
Thanks
Old Aug 16, 2018 | 07:13 AM
Terminals are standard, you can buy them just about anywhere.
Clips, on the other hand..... those are likely going to be dealer only, or junkyard.
Old Aug 16, 2018 | 07:21 AM
RalphP's Avatar
RalphP
This.
The terminals can be found at DigiKey and Mouser; all too many variants, AAMOF.
The clips tend to be specific to where they're used, and as Hey You said, boneyard or dealer.
RwP
Old Aug 17, 2018 | 09:34 AM
93 ragtop's Avatar
93 ragtop
Thanks for both of your replys. I have some universal pigtails for relays..... I can use the terminals out of those but they do not work as well as the factory ones.
Old Aug 17, 2018 | 10:39 AM
RalphP's Avatar
RalphP
You can always order the OEM terminals from DigiKey.
I find these https://www.digikey.com/product-deta...2CT-ND/2816440 .
RwP
