I shoulda stood in bed ...
You ever have one of those days?
The days where you think you should have stayed in bed?
Yesterday, while driving the Dakota, the turn signal indicator decided it had erectile dysfunction.
That is, it just flopped in the breeze.
Turns out ... the tilt/interval wiper switch unit (that the turn signal stalk bolts to, and that has a cam surface for the lever that actually ACTUATES the turn signals) decided it was tired of being one piece, and decided to go bikini mode; i.e., an upper piece and a lower piece.
JB KwikWeld is applied while I hope it keeps it running long enough to get a replacement in.
RwP
RwP
RwP
RwP
Pretty much. Well, that, and managed to lose the nut that holds the steering wheel on. So I ordered two more today; I'll find the other one in a couple of days.
The pot metal that's broken is integral to the 4221903 wiper control switch. Which said switch is NLA, and doesn't show up at SMP or BWD or any other after market place. Le sigh.
Arizona Parts also doesn't list it.
I've found ONE online; I'll find out tomorrow if it's real, it's actual, and everything is satisfactual. :P
Or not.
I'll have to tear a few tilt columns apart in the boneyard, it seems. 87-90 tilt with intermittent wipers is the only sure match; a 1986 Daytona lists the same part, but I have no idea what other cars and trucks used it.
Save I don't think any other trucks did; the parts list shows different numbers for 88-89.
RwP
Or not.
RwP
I may be luckier than I thought; even if it IS NLA in all its forms.
According to a FMJ forum (from a for sale posting in 2017):
I may have a bit more luck finding one of the OTHER numbers.
RwP
Windshield Wiper and Washer Switch with Intermittent Wipers and with Tilt Part # 4439026 (# stamped on part tag is 4373336
Part # is 4439026. Other part #'s superseded or the same as part # 4439026=4373336, 4221783, 4333489, 4439025, 4439063, 4333488, 4360094, 4439028, 4221903, 4221486, 4333999.
RwP
None of the broken piece, alas.
Silke Parts in Jacksonville FL has at least one - or had at least one! - of the wiper switches.
SILKE'S AUTO PARTS INC.
Phone # 904 737 8600
Found via PartsVoice.COM (see below)
Places to add for looking for parts:
http://rearcounter.com
http://partsvoice.com
Both have a collection of NOS part vendors; they show parts that my GoogleFu does not turn up anywhere else. They don't have IDENTICAL lists, so I'd search both. You DO have to have the original part number; thankfully, the Mopar parts listings are in the FAQ here for our trucks.
Don't forget also
http://arizonaparts.com
Brad's NOS parts had the "Quality Engineering By Chrysler Corporation" stickers to refresh my sill plates.
http://bradsnosparts.com .
Alas, you usually have to inquire via email what the actual price is. But that part is free, and comes with a picture in case there's been a horrible misunderstanding between the parts lists in the FAQ and the stocking at Brad's
I have learned more about finding NOS Mopar parts than I would ever want to know.
RwP
Don't forget also
RwP
Trending Topics
"I didn't need that, but it helped!"
Column is in, but I need to snug bolts down. Also reset the set screws on the intermediate shaft - I had to disassemble it to get it all back together.
Plus wire it in.
Plus rebuild wiper transmission.
Right now, I'm about to get a shower and go make a few dinero to PAY for all this repair work.
RwP
Plus wire it in.
RwP
Bolts snugged, connectors (save for the interval wiper module!) connected (IWM is out so I can trace the circuit for future repairs, also in case they become completely unobtainium.)
Rain moved in as I was getting the old transmission out; I used my other spare one (!!) to lay out the bushings on the powder coated arms.
I'll have to put it in later when it's not raining.
RwP
RwP
