What size/type screws are used to reattach the knee blocker?
Old Sep 2, 2018 | 03:29 PM
93422's Avatar
93422
Default What size/type screws are used to reattach the knee bolster?
I had to remove my knee bolster and dash bezel recently and somehow I lost the two screws that screw the bolster into place.
I know there are two screws about 2 inches long that screw the hood release latch into the knee bolster - I still have those. I just have no idea what size the other two screws are.
Old Sep 2, 2018 | 09:34 PM
tbugden's Avatar
tbugden
Should be able to find the identical screws on the passenger side no? If not I can go check mine.
Old Sep 2, 2018 | 09:37 PM
93422's Avatar
93422
I'll go take a look right now. I can't believe I didn't think of that!
Old Sep 2, 2018 | 09:47 PM
93422's Avatar
93422
so as luck would have it there's only one screw on the passenger side, I don't know what happened with the other ones they must have been removed before I took possession of the truck. But the one remaining screw is super tight and I can't get it loose - and I'm not sure I want to; I don't want to risk the half dash potentially coming down. If you could check yours, that would be awesome.
Old Sep 2, 2018 | 11:20 PM
tbugden's Avatar
tbugden
phillips head 0.75" from top to bottom, 0.5" wide head, 0.16" diameter threads which works out to about 5/32 ? Granted there were some mismatched screws in both my Dakotas but those seem to be the originals haha...no guarantees...
Old Sep 3, 2018 | 10:17 AM
onemore94dak's Avatar
onemore94dak
Spare parts boss?
Old Sep 3, 2018 | 11:03 PM
93422's Avatar
93422
Okay so I got the correct screws from hardware and I attempted to put the knee bolster back in place but for some reason the screws won't take, they're not biting. I don't know what the problem is. I had previously removed and replaced the knee bolster several times so maybe that has something to do with it.
Old Sep 4, 2018 | 06:44 AM
Are they just sheet metal screws, and holes in the metal framing for the dash? Or are there supposed to be the little steel clips that they screw into?
