PDC fuses?
Old Oct 10, 2018 | 12:01 PM
93 ragtop's Avatar
93 ragtop
Default PDC fuses?
I purchased a used PDC box from a 92 or 93 dakota. However it did not come with the fuses or relays. I have relays that will work with it, but having trouble finding the fuses.
I copied a picture from forum member ragged89...... The picture below shows the fuses I think I need.
Can someone tell me the style etc. so I can order some?
Thanks
Old Oct 10, 2018 | 12:44 PM
tbugden's Avatar
tbugden
Hmm mine doesn't have those (otherwise I'd send them to you), I assume they're for electric fans then?
Old Oct 10, 2018 | 01:04 PM
93 ragtop's Avatar
93 ragtop
Tbug,
Thanks for your reply.
Below is the picture of the actual box I have.
I assumed this was the fuses needed but I could be wrong
BTW im open to suggestions!!
Old Oct 10, 2018 | 01:17 PM
tbugden's Avatar
tbugden
AH! You mean the big square fuses, I was drawn to looking at the fan fuses and thought there was something special about them.
Those big fuses I have and you can have all of them if you want them! edit: I'm sure you can pull 'em out of a truck at the yard too, check other Dodges of the same period. But I'm happy to send them to you all the same.
Old Oct 10, 2018 | 01:56 PM
onemore94dak's Avatar
onemore94dak
They seem to be called "low profile fuses" and or Cartridge fuses in case you are searching for new. I couldn't get the PDC doc to open and the pics of fuse boxes are no longer good on the FAQ page. I found nothing on Rock Auto
Old Oct 10, 2018 | 07:34 PM
RalphP's Avatar
RalphP
Bussmann calls them "fusible links", and that's how they're listed at AutoZone and most auto supply stores.
See https://www.autozone.com/electrical-...9973?location=
RwP
Old Oct 14, 2018 | 07:28 AM
93 ragtop's Avatar
93 ragtop
Hey guys,
Thanks for your help and suggestions. Tbug is taking care of me and sending me what I need!!
Thanks again
