changing starter having problems installing it
Old Dec 10, 2005 | 10:00 PM
rafael's Avatar
rafael
Default changing starter having problems installing it
I have a 93 dodge sport 3.9 v6, I had problems with the ignition so I bought a new battery and still the problem was there. I took out the starter but I cant get it out, I need to know how to remove the steering shaff anyone knows plz help me out..levi
Old Dec 16, 2005 | 02:05 AM
360DakotaPwr's Avatar
360DakotaPwr
Default RE: changing starter having problems installing it
There is a bolt halfway down and one where it meets the rack. This should take it loose.
Cant you take it out the bottom?
Old Dec 16, 2005 | 11:10 PM
rafael's Avatar
rafael
I was able to take out the starter by taking out the middle bolt on the steering column staft and bending it a bit to slide it to one side, I have a feeling I messed something up. I didnt use the bolt at the bottom of the steering shaft (was that the bolt you punch out). The manual says you can take it out thru the bottom but the exhaust pipes and heat shield is in the way
Old Dec 18, 2005 | 03:08 AM
360DakotaPwr
I dunno man, I took mine out through the bottom with the exhaust and everything still bolted up. It should pass between a bracket ang the tranny bellhousing.
Old Dec 21, 2005 | 01:28 PM
JDakota92's Avatar
JDakota92
I did mine and was able to take it out the bottom as well. I have the 5.2, but it's the same setup.
