Getting top nut off shock.
They actually make a tool just for this ...
Worst case, take an angle grinder against the shaft right at the bottom of the outer nut, right against the frame there.
But before you do that .. soak it in your favorite rust buster (I like PBlaster or Kroil myself; but there's others out there) and get that rust loosened up.
RwP
RwP
They actually make a tool just for this ... https://www.amazon.com/Lisle-20400-U.../dp/B000CO88C6
RwP
RwP
Well I'll be dang......
Because they actually make a tool for the upper shock mount? I had one of those tools, albeit I doubt it was a Lisle, back in the early 70's when I owned a 1963 Biscayne ...
RwP
RwP
Trending Topics
Trick is use is to put vice grips on the shaft of the shock, turn the top nut wrench until the vise grips lock themselves in on the mount, then reef on it. I will warn you, to get mine off I damaged the vice grips because I used a pipe wrench to tighten the nut on the vice grips to get them tight enough and it wrecked the threads to adjust my vice grips. I assume your changing the shocks and then in turn wouldn't worry about damaging the shock shaft. When I did this both of the shocks broke on the threaded portion where the nut is. Angle grinders work but this is much easier and less sparks/mess. Just need a good cheater on the wrench. I actually made a rubber boot to go over that top nut so this doesn't happen again, and then loaded it with anti seize on the remaining threads before covering.
It was a bit time consuming because of the room I had to turn the wrench, but got it off.
My question is, is the front supposed to sit lower then the rear? While this did fix a issue, it seems the height was only adjusted a little. It sits about 1 1/2-2" lower than the rear.
Yes. I was searching up YouTube video and everyone was a mcgiver solution. While I dig the spirit and pride myself on it when I don't have the tools on me, I didn't bother to see if there was a tool specifically made FOR THIS.
