Been trying to source a cold air intake for 93 Dakota with the 5.2L and I'm coming up empty handed. Does anyone have a 'cross-reference' vendor / part # they like that will work on my truck! Thanks for the thoughts!
onemore94dak
close
- Join DateSep 2013
Liked:153 Times in 145 Posts
If you have a stock air intake and it has the tube from the air cleaner to the grill that is a cold air intake. Its the coldest air you are going to get for intake combustion.
I'm guessing some genius previous owner pulled the stock tube off and rigged up some design such that the engine now intakes from the engine bay? If that is the case then just go to the junkyard and find a stock intake tube then go find the P/O and smack him/her in the face with it and then install it on your truck.
RalphP
close
- Join DateJan 2013
- LocationNorthwest Louisiana
Liked:374 Times in 345 Posts
Quote:
Quote:
These guys are smart.Originally Posted by tbugden
It's as cold as you're going to find in the truck; considering most CAIs suck hot air from the engine bay, they're like most bills in Congress - name is usually the exact opposite of what it does!
RwP
RwP
I take offense to that! I firmly believe that Congress is both effective and swift!Originally Posted by RalphP
These guys are smart.It's as cold as you're going to find in the truck; considering most CAIs suck hot air from the engine bay, they're like most bills in Congress - name is usually the exact opposite of what it does!
RwP
/s
RalphP
close
- Join DateJan 2013
Quote:
/s
Ummm ... Nurse? I think the happy juice in TBugden's IV is running JEEST a bit too high ...Originally Posted by tbugden
I take offense to that! I firmly believe that Congress is both effective and swift!/s
RwP
onemore94dak
close
- Join DateSep 2013
Suppose you were an idiot. And suppose you were a member of Congress. But I repeat myself.
- Mark Twain
- Mark Twain
... so this poor truck has been 'ridden hard and put away wet',.. a really interesting mix of aftermarket, and modified stock that makes for a somewhat strange driving / off-roading experience. Having said that,..
The spring project is a top-end rebuild with an new intake and throttle-body and since I wouldn't ever replace what's been constructed for an air intake,.. was fishing around to see what you guys/gals have done.
Tim over at Hughes is gonna sell me this Eldebrock intake with a modified throttle body but he couldn't hook me up with the cold air intake,... thus my question..
I can do the fabrications needed if someone has modified an off-the shelf cold air intake,.. so just seeing what others had crafted up and they like.
Always interested to hear thoughts / ideas?!
RalphP
close
- Join DateJan 2013
I use Hastings or Wix air filters in my 1988 to augment the factory CAI; even Fram's air filters are pretty darn good.
I'd grab a factory unit and replace whatever the PO's have bodged in there.
RwP
RwP
