1992 possible pcm problem??
Old Apr 22, 2019 | 09:24 PM
littleBlue52's Avatar
littleBlue52
Default 1992 possible pcm problem??
I recently purchased a 1992 Dakota 5.2 came with a cold air kit, lowered, pillar gauge set up, chrome rt wheels,Gibson headers. I noticed a bunch of new things on the engine also. either the intake has been cleaned painted and put back on or its a new intake. new coil, new cam sensor, crank sensor, plugs, wires, and dist. cab. also an orange wire has been spliced into the fuel pump from the bottom of the fuse/relay box under the hood. all the relays were missing so I picked up a few from a local junkyard and tried to start it. it started for about 2secs then cut off. tried again and it just kept cranking but wouldn't start. I sprayed a little starter fluid in it and about 10 tries later it ran for another 2 secs. now its been a few days and nothing but the engine turning over and killing my batteries. looks as if the wire harness has been replaced, zip ties everywhere. maybe my PCM is shot. I have no fuel pressure, a low voltage reading at the coil + and not getting a ground to - side.
Old Apr 22, 2019 | 09:39 PM
Think I would start by looking for a stock wiring harness to clean up, and install. Otherwise, you are going to have a nightmare tracing any electrical gremlins in the future.....
Old Sep 25, 2020 | 09:22 AM
littleBlue52
Default PCM problem
Turns out all the splices were ok. I did redo them and cleaned up a few grounds. But my problem turned out to be a bad PCM
