1989 Dakota high emissions
Old May 14, 2019 | 10:11 AM
dptropepe's Avatar
dptropepe
Default 1989 Dakota high emissions
Hi, all. I have an 89 Dakota 2.5 5 speed base model. It has 319,100 miles and counting. It has high tail pipe emissions. The scanner shows all the sensors are within parameters. I think. The injector pulse stays at 1.0 MS till you let off the throttle. Then it comes down to .5 MS. Is this normal for a throttle body? The truck runs great. Thanks in advance for any help.
Old May 14, 2019 | 10:20 AM
93 ragtop's Avatar
93 ragtop
What is high? ie: hydrocarbons? etc. Does the truck burn oil? Cat still on the truck? Oh, and how far out of specs was it when tested?
Old May 15, 2019 | 09:33 AM
dptropepe's Avatar
dptropepe
My real concern is the injector pulse width. MPFI changes the injector pulse width depending on load, temp, ect. I am not as familiar with TBI.
Old May 15, 2019 | 02:23 PM
Works pretty much the same way, just fewer injectors.
Old May 17, 2019 | 11:51 PM
WolfStar's Avatar
WolfStar
Hi, all. I have an 89 Dakota 2.5 5 speed base model. It has 319,100 moles and counting. It has high tail pipe emissions. The scanner shows all the sensors are within parameters. I think. The injector pulse stays at 1.0 MS till you let off the throttle. Then it comes down to .5 MS. Is this normal for a throttle body? The truck runs great. Thanks in advance for any help.
Is there an EGR system on this truck? I failed emissions a long time ago with high NOx and it was the EGR valve that was defective. If so you can try cleaning it out or buying a new one - sometimes the passages get jammed up with carbon or the solenoid fails. I remember around $75 from the dealer but that was a long time ago.
