Tuneup - What'd I do Wrong?
Old 05-28-2019, 07:41 PM
RoanokeDakota's Avatar
RoanokeDakota
RoanokeDakota is offline
Default Tuneup - What'd I do Wrong?
(1995 V6/automatic)
Finally got around to changing plugs & wires,
distributor cap & rotor,& changed the oil.
When I started it up,after replacing parts,it runs fine,then stumbles,
runs fine,then stumbles,etc..... Also get a stumble around 1250 RPM.
The muffler will also need to be replaced,as it leaks a little (age).
I checked all the connections on the cap & at the spark plugs.Any ideas
on what I might have done wrong?
Thanks in advance ( in case I forget).
Old 05-28-2019, 09:09 PM
RalphP's Avatar
RalphP
RalphP is offline
Swapped plug order?
Did you see the TSB on spark wire routing? http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
RwP
Old 05-29-2019, 10:25 PM
RoanokeDakota
Had two wires switched,& engine wouldn't start.
Corrected that,started,but rough idle,& missing.
Rerouted coil cable,& runs really bad.It's got to
be something simple.
How about removing the metal "tubes" around
the spark plugs - bad idea?
Old 05-30-2019, 09:49 AM
onemore94dak's Avatar
onemore94dak
onemore94dak is offline
Those tubes are meant to be heat shields for the wire.I don't have them on mine, if I did I would probably leave them since the rerouting of the wires TSB to get them away from the heat made a noticeable difference.
I would start looking for connections you were not even working on that you may have knocked loose.
Old 05-30-2019, 01:55 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,391 Likes on 3,131 Posts
The TSB for rerouting the wires wasn't about heat, it was about cross-talk on the wires. The heat shields can be removed without consequence.
Quick Reply: Tuneup - What'd I do Wrong?
