How to adjust tailgate '95 Dakota?
Aug 31, 2019 | 10:12 PM
I loosened the strikers and moved them in on both sides. Helped a little. Fairly close on RH side but almost 1/4" out on LH side. Any ideas?
Also, it seems kinda loose at the pivot points. Is there maybe a plastic bushing the goes in the hole that I'm not aware of? Red arrow...…..
Sep 1, 2019 | 09:18 AM
I do believe there are bushings for the pivot points on the tailgate.
Are the latches on the tailgate itself adjustable??
Sep 1, 2019 | 11:00 AM
It's been a while since I've had a Dakota but I believe the upper catch is adjustable also. It's basically a big round bolt that the upper latch catches on.
Sep 1, 2019 | 10:54 PM
No, the latches are not adjustable.
Are those bushings available from the dealer or is it a specialty market piece?
Sep 2, 2019 | 09:52 AM
evintho
I think you can get them from just about any parts store..... call around and ask.
Sep 2, 2019 | 12:14 PM
evintho
No, the latches don't have much adjustment. The catches they grab are though. If you look, there's a place for a Torx or Allen head wrench.
It's above the tail gate strap.
