Anyone running larger oil filter?
Old Nov 18, 2019 | 02:05 AM
glenlloyd's Avatar
glenlloyd
Default Anyone running larger oil filter?
I searched for anything about this before posting up but didn't really see anything specific about it.
Wanted to know if anyone is running a larger capacity filter and if so which one?
I get Mann 940/25 filters for my VW tdi diesels and noticed it's almost identical in seal size and that threads are the same. Capacity is quite a bit more than standard filters but I believe it will fit in the space.
If you are doing something else please post up what you are doing.
Thanks
Steve A
Old Nov 18, 2019 | 04:41 AM
RalphP's Avatar
RalphP
FL300A Motorcraft. Also fits the Cougar and is a shorl FL1A.
RwP
Old Nov 18, 2019 | 08:52 AM
00t444e's Avatar
00t444e
I use the motorcraft FL1A it fits all of the magnum engines and the my Jeep 4.0.
Old Nov 18, 2019 | 09:45 AM
RalphP's Avatar
RalphP
Yah, it fits the engine. Alas, my 1988 Dakota has a frame rail in the way of it ...
RwP
Old Nov 18, 2019 | 11:09 AM
glenlloyd's Avatar
glenlloyd
RwP
Ralph I'm not finding a FL300A, only the FL300, which looks about like it's the same as the Delco gold I've been using on the Dak.
The Mann 940/25 is a full 1" longer than the FL1A, I still don't think there's any reason why it won't fit on 4x2 but before I commit to using it I'll do a test fitting. I'm switching over to synth this next change and it's just about time to do it.
If the Mann filter fits that means that for three vehicles I only need to stock one filter. Actually that would cover 4 vehicles but hopefully the fourth is going away...
Thanks
Steve A
Old Nov 18, 2019 | 02:27 PM
onemore94dak's Avatar
onemore94dak
I use the higher quality option from NAPA which is noticeably fatter than the cheaper filter.
