Facepalms.
Old Mar 5, 2020 | 07:41 PM
RalphP's Avatar
RalphP
Default Facepalms.
I know that some of you probably feel like this about me at times:
But.
I discovered the buzzing at the front of the motor at idle.
For 1988 (and most of the LAs I bet!) there's a bracket that bolts to the passenger head to hold the back of the alternator. There's also a brace that goes from there to the front alternator / compressor bracket.
I had one of three bolts (!!!) on the back bracket, and no brace. Haven't ever HAD the brace as far as I know ...
Found the brace on a 1990 Dak in the boneyard (and all the hard vacuum lines, in great shape! 'Nuther story about why I ought to do all my own work on my truck ...) and replaced the missing bolt(s) (grabbed the one that held the brace also while grabbing the brace) (Note: 3/8-16 x 1" flange head bolts did fine for the back brace) and tightened up the one bolt I had earlier.
No buzzing!!!
And the pulley is now parallel, not bending towards the fan as I tighten up the belts (wasn't much, but you could see it.)
I feel much better now.
RwP
Old Mar 6, 2020 | 06:14 AM
93 ragtop's Avatar
93 ragtop
Ralph, I did something similar..... I have a 93 corvette, and about 15-20 years ago, I swapped heads, and added headers. There was a brace that went from the ac compressor to the exhaust manifold. I left it off..... Afterwards, I had a vibration when the AC was on. Long story short, took about a year for me to figure that one out. As we both know, them braces are on there for a reason!!
Old Mar 6, 2020 | 06:53 AM
RalphP's Avatar
RalphP
In my defense, that brace was missing when I obtained the truck; but it makes good sense to me where it fits.
Pull the alternator and you can even reach its bolts. So I did my bolt installs with the alternator sitting over by the radiator on top of the evap canister.
I have to do the vacuum lines yet; it was getting too dark last night.
But at least it doesn't buzz and rattle anymore.
Yay!
RwP
Old Mar 7, 2020 | 12:38 PM
onemore94dak's Avatar
onemore94dak
So I had the rear lights off last summer to clean up the paint and do the bumper.
Then I ran out of gas the other day and noticed when I got back to the truck that the right side flasher was flashing the reverse light.
Today I was going to replace what I thought was a bad bulb and found out that I had put the reverse light into the backup/brake light slot and the reverse light into the brake spot. Who knew they would both fit in either slot? Not me.
Old Mar 7, 2020 | 12:55 PM
RalphP's Avatar
RalphP
There's actually logic behind that.
They use the same basic molding for both sockets; so both have identical ears on the mounting side.
RwP
