2.5 hanging throttle
Old Mar 16, 2020 | 12:56 PM
gdalton's Avatar
gdalton
Default 2.5 hanging throttle
The symptom is:
Engine does not come back down to normal idle speed quickly, it hangs for a 3-4 seconds after releasing the throttle. It started doing this randomly several weeks ago.
Otherwise the engine seems to run fine.
What I have done:
new IAC
New wires, plugs, distributor, ignition coil
Unplugged the computer for 30 minutes in attempt to reset it
All to no avail. What do you guys think?
Thanks
Old Mar 16, 2020 | 06:57 PM
RalphP's Avatar
RalphP
Check your throttle return springs?
If they're weak, it'll be slow returning anyway.
RwP
Old Mar 16, 2020 | 07:16 PM
gdalton's Avatar
gdalton
good thought, I just checked and the throttle snaps back nicely.
Old Mar 17, 2020 | 02:27 PM
onemore94dak's Avatar
onemore94dak
What year? There is a 95 and 96 factory service manual in the FAQ section. I'd look at how to set the timing on the 2.5 motor. Could be the air intake is clogged? or a vacuum leak? I think it should also tell you how to adjust the carb.
Old Mar 20, 2020 | 06:35 PM
gdalton's Avatar
gdalton
i'm starting to think vacuum leak as well. This is going to sound naive but is there a vacuum line kit for the Dakotas?
Old Mar 20, 2020 | 06:39 PM
RalphP's Avatar
RalphP
Kinda sorta - it's called "Buy some vacuum line and some clamps, and roll your own."
Or find a matching truck in the boneyard with a good set.
Just as a suggestion: If you use the old hard line to stub into some silicon or rubber vacuum line, I'd use some Automotive Goop to seal that with since you really don't want to clamp onto the old plastic and break it of fworse.
RwP
