Fault code 34
Old Jun 18, 2020 | 09:35 PM
Joshua Edens's Avatar
Joshua Edens
Default Fault code 34
Thanks for all the past help, you all have been great.
I have...
Code 34: An open or shorted condition detected in the speed control vaccum or vent solenoid circuits.
I have recently replaced the IAC, fuel filter and serviced the entire truck. It is a 1993 Dakota LE automatic v6 and does have cruise control that does not work.
How do I go about getting rid of this code?
thanks
Old Jun 18, 2020 | 09:57 PM
Fix the cruise control.
Yeah, that was really helpful, wasn't it....
You have an open or short in one of the control circuits. Easiest thing is to check and make sure everything is plugged in. (don't know where they stash the cruise servo on your truck though.....) Both circuits are controlled by the PCM. Might be a pinched/cut wire, might be a bad solenoid in the cruise servo.
Old Jun 19, 2020 | 11:50 AM
Joshua Edens
update: Took it out on the highway, cruise control works perfect. The engine takes 1-3 seconds when I shift from P-D and D-P with the biggest fluctuation in rpm coming when I turn the truck on and when I shift into park. The rpm bounces from 500-1100 for about 3 seconds before settling around 850. Code 34 still shown. Any ideas? Wires look to be all connected and in good shape.
Old Jun 19, 2020 | 03:21 PM
Clear the codes, see if it comes back.
Old Jun 19, 2020 | 03:36 PM
Joshua Edens
I have tried disconnected the battery to clear the codes, still comes back code 34.
Old Jun 19, 2020 | 07:37 PM
Have a look here. Think since your cruise works, I would start with the resistance test on the servo.
