cooling fan circut
Old Aug 15, 2020 | 02:56 PM
Dearolddadsgarageexperiment's Avatar
Default cooling fan circut
where is the relay and sensor. i don't know if it has ever worked, i've never heard it run.
Old Aug 15, 2020 | 06:44 PM
RalphP's Avatar
RalphP
I happen to remember it's a 1990 2.5 .
The relay is on the driver's side inner fender, as noted in the factory service manual.
The sensor - well, it uses the engine coolant temperature (ECT) sensor since it's driven off the ECU.
RwP
Old Aug 15, 2020 | 08:28 PM
which sensor is the ect sensor? the one on the thermostat housing or the one on the side of the cylinder head with one wire?
Old Aug 15, 2020 | 09:38 PM
RalphP's Avatar
RalphP
One wire is for the gauge; two wire is ECT.
But.
Before I fiddled with THAT any, I'd check the relay.
I'd also check the fan itself; fan could be failed.
Time to grab the multi meter and at worst, jump the relay contacts.
To do this, open up the factory service manual (which you should have by now! If not, ORDER IT!!!!!!) and follow its troubleshooting.
RwP
Old Aug 16, 2020 | 10:43 AM
93 ragtop's Avatar
93 ragtop
What Ralph said!!
In addition, sometimes troubleshooting can be as simple as, grab the fan blade and see if the motor spins freely. If seized...... theres your trouble.
Old Sep 4, 2020 | 12:59 PM
got it fixed it was running just real quiet.
