Code 41 and 46 overcharging
Old Aug 28, 2020 | 10:41 PM
mopar1970440's Avatar
mopar1970440
Default Code 41 and 46 overcharging
1994 Dakota 5.2
I purchased this truck a few months ago. Truck Already had a newer alternator and ECM dated 4/20 on reman sticker. I’m Getting codes 41 and 46 , battery is getting overcharged anytime the throttle is above idle It goes to 17-17.5 volts per test meter reading .My understanding is the ECM controls regulating. I’ve read posts that have said this could be wiring or the ECM. What wiring do I need to look at? Can I test the ECM myself?? Thanks!
Old Aug 29, 2020 | 09:29 AM
Yep, PCM has the regulator in it. If the alt is overcharging, regulator isn't doing its job. You can go with an external regulator, or, replace the PCM......
onemore94dak's Avatar
onemore94dak
I have no idea how you could test teh PCM. I remember someone else on here putting in an external regulator to deal with a similar issue of a PCM regulator that failed but otherwise worked fine.
