3.9 Black Smoke sometimes under load and at high idle RPMS
Old Nov 3, 2020 | 02:56 PM
Ely Cyrus's Avatar
Ely Cyrus
Default 3.9 Black Smoke sometimes under load and at high idle RPMS
I have a 89 Dakota, has about 40k miles on it.
Black smoke under load, rich fuel smell and when I rev it in neutral it makes a thick cloud of black smoke that smells like gas above 2k rpm or so.
I changed the O2 sensor, Temp sensor, and MAP sensor, and fuel pressure regulator.
I ordered a EGR valve to replace what's on there, any thing else I can try?
Idle's fine, and it seems like it only does this once it is warmed up, which is why I changed the temp sensor.
Old Nov 3, 2020 | 04:30 PM
Which temp sensor did you change? I suspect that there are two on your truck. One-wire sensor is for the gauge, two-wire sensor is for the computer.
Old Nov 3, 2020 | 05:04 PM
Ely Cyrus's Avatar
Ely Cyrus
both, made that mistake and only changed the single wire then realized there were two and swapped that one as well
Old Nov 3, 2020 | 05:16 PM
Can you plug in with a scanner, and see what the PCM thinks the temp is?
Old Nov 3, 2020 | 07:14 PM
Ely Cyrus's Avatar
Ely Cyrus
It's a 89, will any code reader bring up live data?
Is there one you can reccommend
Old Nov 3, 2020 | 08:02 PM
RalphP's Avatar
RalphP
I have a used SnapOn MT-2500 that I bought off eBay with the cartridges for my 1988; it'll read some live data.
RwP
Old Nov 3, 2020 | 08:39 PM
Yeah, the snap-on MT2500, or MTG2500 is a good scanner if it comes with all its cartridges/personality keys. It will read pretty much everything the PCM is willing to tell you. Not inexpensive, but, works on OBDI, and OBDII up to something like 2006 or so.
