Gas tank swap
Old Nov 25, 2020 | 06:47 AM
Timothy Hamm's Avatar
Timothy Hamm
Default Gas tank swap
I have a 90 Dakota LE Extended cab. Will the gas tank from a 91 Dakota fit. I know I have to change the electrical plug for the fuel pump assembly
Old Nov 25, 2020 | 06:54 AM
Welcome to DF. Going to move this to the first gen dakota section for ya.
Old Nov 25, 2020 | 10:33 AM
RalphP's Avatar
RalphP
I have not done this yes - but I believe it will, if!
1) Change the plug to match.
2) Carefully replumb all the lines.
3) If yours has the DRAIN line, which the 1991+ didn't, you can ignore that; that was to allow draining the tank with an external pump if the electric pump failed on a full tank.
I would replace the straps also.
RwP
