No start
Old Jan 20, 2021 | 02:41 PM
corpau's Avatar
corpau
Question No start
My neighbor has a gen 1 dakota 4x4 i believe v6 i can buy it cheap but i dont know whats wrong you can hear the starter spinning but the motor not doing a thing should i keep clear of it or somewhat easy fix
Old Jan 20, 2021 | 04:00 PM
onemore94dak's Avatar
onemore94dak
If you can wrench well enough to follow instructions and know enough to be able to search for answers, its a good rig to have. You might consider paying a mechanic to inspect it and diagnose the problem if the seller cannot tell you. Otherwise you are better off buying something you know will run well.
Old Jan 20, 2021 | 09:43 PM
IF the starter is running, but the motor is not turning, might be as simple as replacing the starter. Might be as bad as a broken crankshaft..... Gonna have to take some stuff apart to see.
